iPhone 6 keeps beeping when charging
Hello everyone,,
I plugged my iPhone into my Macbook Pro to recharge it. As usual, the iTunes window appeared and syncing began, but the phone kept beeping. I unplugged it and used the same cable to plug into an electrical outlet and it's charging just fine with no beeps.
What is causing the beeping when I connect to my laptop and how can I fix that? No problems for the past 3 years. This is a new one for me and can't find a solution.
Thanks much!
Re: iPhone 6 keeps beeping when charging
Maestro
Could it be an issue with cable? Maybe it's picking up the charge and then not and then picking it up (on off on off) and that's the beeping?
Posted From Samsung SM-N960F
Maestro
@KidBooo wrote:
Hello everyone,,
Thanks much!
* post has been editted
Thank you my issue has been solved,,,...
Hello everyone,,
I plugged my iPhone into my Macbook Pro to recharge it. As usual, the iTunes window appeared and syncing began but the phone kept beeping. I unplugged it and used the same cable to plug into an electrical outlet and it's charging just fine with no beeps.
Thanks much!
Thank you my issue has been solved,..
