Roaming not working in France
Hi there I am on the 20 Euro plan so should have up to 6gb of data to use in Europe. However the data is not working at all - I can’t access the internet. The roaming settings on my phone are fine. Can you please fix it ASAP as I need to use google maps etc ? Thank you!
Re: Roaming not working in France
What phone do you have?
Try to disable 4G (As you cant register on 4G networks when roaming)
When you do a manual search can you see the Orange network?
Maestro
Hi gabrielledoyle1,
What network are you connected to in France? I'll check this out for you.
