Re: Roaming issues
Hi @Three_Deborah1 yes I ensured data roaming is enabled and still doesn't work. I'm also having issues placing calls and sending texts.
Re: Roaming issues
Have you manually selected a different network? What network is showing at the moment?
Re: Roaming issues
Im currently on Telekom.ro which is the default network
Re: Roaming issues
I did not change the network from the default
Re: Roaming issues
Can you try selecting another network? Are you able to receive calls/text?
Re: Roaming issues
I've tried selecting a new network but it just keeps loading and no options offered
Re: Roaming issues
@lale just send your number in a PM to mods so they can have it looked at
Re: Roaming issues
Ok thanks
Re: Roaming issues
Try to enable 3g only and restart phone
