Highlighted
Roaming is not working in Italy
Hi, topping up with 20 euros should allow 6gb of roaming data in Italy but so far I cannot use my phone outside the hotel where there is wifi. I have tried restarting the phone and selecting networks manually. It connects to a network but the phone(note 8) says I am offline. Any suggestons please?
Highlighted
Re: Roaming is not working in Italy
That's great @onejohn72 👌If you accept this as a solution, it means another customer with a similar query will be able to find this quicker. Have a fantastic time on your holidays 😄
Highlighted
Hi @onejohn72 👋 Can you turn off 4G, enable data roaming and manually connect to either 3 or Wind? Let me know how you get on 👍 Aoife
Highlighted
Hi yes I connected to WIND and now it works. Thanks!
Highlighted
Highlighted
Hello, I have the same problem now in Italy. I have already selected wind but the data roaming toggle option is inactive and grayed out. It doesn't allow me to change it. Please can you help?
Highlighted
As in you cant turn on data roaming from your settings? Is there more than one wind option and have you tried any others?
Highlighted
Enable 3g only and restart your phone
Three – Covid-19
