Roaming in Argentina
My phone will not connect to a local network in Argentina. There are 3 providers but I am unable to connect, even manually.
Is there any setting that has to happen on your end to activate this?
I'm on an iPhone 6S.
Juan
Re: Roaming in Argentina
Maestro
Hi Juan,
Do see the networks Claro and Telecom in your network settings? Have you got roaming enabled in the settings?
I was able to select Personal but I can't make calls or send text messages
Maestro
Can you PM me the name, address, date of birth & number? I'll check this out for you 👍
