Roaming Issue
Hello, calling or data does not work on my iphone in France.
I have checked with My3 for my balance and roaming permissions and they’re all fine, but for some reason I’m unable to make any calls at all, even to the free and paid phone helplines on 3.
My reception is fine. I have restarted my phone to check too.
I am not sure what to do and has brought me much inconvenience.
I hope 3 will be able to help me with this. Thank you very much.
Re: Roaming Issue
Can you PM me your full name, number, registered address and date of birth so I can access your account? Can you also take a look at this link here and let me know if this helps 👉 http://bit.ly/2wLOCNa
Re: Roaming Issue
Maestro
Hi @kwan213, can you turn off 4G on your phone and just connect to the 2G/3G network and then select Nova or Orange network?  Let me know if this works for you 👍
Re: Roaming Issue
try selecting Bouygues and restarting the phone
Re: Roaming Issue
Hi Julie, I have tried your method and also restarted my phone but in vain.
Re: Roaming Issue
Re: Roaming Issue
I have a same problem. I'm in France and I got €20.
Eventhough I tried everything that I could find, still I can't connect the internet.
Re: Roaming Issue
Maestro
Hi @ysy3529, what network are you connected to? You can check out more info on roaming here: 3.ie/eu8sj Can you also send your details in PM and I can take a closer look?
Re: Roaming Issue
I have same problem. I see network but calls or data is not working while roaming in Greece. This the 2nd time now. Last time my trip to Germany was completely ruined.
Re: Roaming Issue
Hi Vvs 👋 I'm very sorry to hear that! Have you tried the steps on this thread already? If you have, can you pop me a PM with the details and I'll check the account for you? Conor
