Roaming HELP!
I’m roaming on an iPhone 6s. I can’t make outgoing calls and when I dial my number from friends phone my phone goes straight to voicemail.
I have asked 3 chat but they are escalating but I fear I’ll be home by the time the tech team have checked
So far we have reset network settings, manually selected all available providers on the phone and ensured 4 g is not enabled
Any help please?
Re: Roaming HELP!
@Kfiddle Have you ever used that phone roaming before and where are you on holidays. You mentioned calls but can you get them like is there a signal?
Re: Roaming HELP!
Thanks for reply. Never used this phone abroad before. In Netherlands have full (4bars) coverage. Cannot make or receive calls
Re: Roaming HELP!
What network are you on? Credit? If you're prepay.
Re: Roaming HELP!
On kpn nl. Sorry I’m bill pay. Just realized I put this in prepay section
Re: Roaming HELP!
Okay and what if you select other networks? It's weird cuz you have signal so Sim is connected. To me that means maybe phone is issue. Try other networks and see?
Re: Roaming HELP!
Ye tried them all with chat earlier. When I call voicemail (for example ) I get a automated message saying I’ve no access
For info I was roaming on another device earlier this year and calls and texts were also not working
Thought that was a phone issue too but maybe not. Is there anything you can think of?
Re: Roaming HELP!
Did you get a different SIM since your last trip? If not then that's the common denominator. If that's not the case then I think the escalation is your only choice. What of you ask the mods here. @Three_Mairead or @ThreeLisa can ye also do the escalating to help here?
Re: Roaming HELP!
Genuinely can’t remember on sim. Moved from htc to iPhone 6s , do you know if that’s a sim change?
Thanks for help. If anyone can assist that would be great
Re: Roaming HELP!
Think it could be the same but not too sure. @Three_Lisa @Three_Mairead usually lend a hand when its needed
