Prepay Parkingtag
Hey,
I got a text earlier linking to a blog post that says i can pay for parking on Parkingtag.ie using left over credit, which sounds like e a great idea!
I can't see how to do this anywhere on the Parkingtag App, and it won't let me delete the debit card already associated.
Does anyone know how i can use my phone credit to pay for parking with parkingtag.ie
Re: Prepay Parkingtag
Don't you just send the text to 53311 ? https://www.parkingtag.ie/how-it-works/charge-to-mobile  Maybe contact their support group to see if they can delete or help you delete the saved card here https://www.parkingtag.ie/contact
If you can use your credit then it should be able to be added to the bill for bill pay like me Smiley Happy Good news all around, carparks can cost a fortune
Ah ok thanks for that. I'd only used the App before so wondered if the option was in that.
I'll try texting next time, may not need to get me card deleted from the App if I'm using the text option.
Cheers
Hope it works!
