No 4g connection
Hi, I just wanted to ask about activating 4G on my sim, I tried to enable 4G access promotion on My3 account but it fails to work. I'm only receiving 3G service on my phone, despite having a 4G compatible phone, 4G enabled in the mobile data settings and a 4G compatible Three sim.
Thanks.
Re: No 4g connection
Hi @johndoe 👋 What type of handset are you using and how old is your SIM card? Where are you based and I'll also check if 4G is available in your area? 👍
