Data issues
I recently joined the network the data only seems to work when I'm in a 3/4g area when I'm not right in the middle of a town/city it won't work I will have full H coverage and it will barely work or loads the Google screen in 5mins, but crazy paying for unlimited data if I can't use it in 90% of the country, would appreciate your help thank you
Posted From Huawei PRA-LX1
Re: Data issues
Wizard
Hi @Liam721, Whereabouts are you and what phone are you using? Can you manually select the network on it?
Re: Data issues
Ballycommon just outside nenagh, using a hauwei p8 lite and it's set to 4g/3g/2g auto
Re: Data issues
Wizard
Is there an option there marked "Network Operators" for this @Liam721?
Re: Data issues
Yes it's does
Re: Data issues
Wizard
Can you try this to manually select the network for this @Liam721
Re: Data issues
Yes I can which should I select
Re: Data issues
What options are showing up? Can you switch between 3G and 2G and let me know what the service is like?
Re: Data issues
Join the club Smiley Wink If you're on three and aren't actually in a town or city your coverage will most likely be garbage. Painfully slow 3G/2G is probably the best you can expect from my experience Smiley Tongue
