Call barring problem
HI. I'm abroad in Colombia and need to ring Ireland urgently. . It's saying call barring us activated and I don't know how to fix it . I have credit. Can anyone please help? Thank you.
Posted From Samsung SM-G900F
Re: Call barring problem
Can you check your settings in my3
Posted From Sony G8441
3 Staff
Hi Moonunit 👋 What prefix are you using when dialling this Irish number? Have you checked your settings?
I also having same issues and need some help with this. I dont have so much technical knowledge but provide me a step by step guide.
Regards,
Shane
Hi Shane 👋 Thanks for contacting us here. I'd like to check your account to make sure it's set up for roaming in Colombia. Can you PM me with your number, address and date of birth? Deb
@ShaneP can you receive calls and texts do you know? If you need to call Ireland from outside country you have to use the 00353 prefix. Then drop the 0 at beginning of Irish number and continue with the rest of numbers like 003531234567 try that?
Posted From Huawei ANE-LX1
