4G speed issue
I am currently experiencing very poor speeds on 4g. speeds will not go above 0.5Mb. i live in carrigmore clogheen tipperary.
i can see others from the same area are having the same issue from this website.
http://downdetector.ie/problems/3
any info would be great.
Re: 4G speed issue
Maestro
Re: 4G speed issue
Maestro
Hi efletcher,
Are you using your mobile data or mobile broadband?
Re: 4G speed issue
i use a three sim card in a 4g router. i was getting close to 40Mb with an external antenna over a week ago.
Re: 4G speed issue
Maestro
Can you take a look at this broadband checklist for me please bit.ly/1TRD3u3 & let me know how you get on.
Re: 4G speed issue
adjusted settings as per
  • Choose “Registration mode” tab, click on “Manual search and register” option and click on “Refresh” button
  • Select “O2-IRL (2G)(3G)” ,click on “Register” button and click “ok” button
  • At the home screen repeat step 3 to 4, change set the “Mode” to “Automatic”
back in action thank you
Re: 4G speed issue
Maestro
Good stuff, glad to hear it!
Re: 4G speed issue
HI there,
I'm having serious speed issues for the last 10 days or so. The Internet is actually unusable after about 7pm. Not great now after 6 either.
Speeds down to between 200kbps and 1mb., normal speeds are about 13mbps on 3g. 4g barely works. What's going on. Have Three yet again oversold their product and are unable to provide usable internet. Damned if I'm going to pay another 16 months for a service that I can't use.
It annoys me that my phone is perfectly ok giving speeds of about 3mbps at the moment which is also way down speedier but usable.
Re: 4G speed issue
Hi @pg12009, I am so sorry to hear this and I'd like to get this sorted for you now. Can you tell me where you are experiencing this so I can take a look at the area and make sure everything is up and running as it should be? Ashlee
Re: 4G speed issue
Hi Ashlee,
I'm in *********
***Edited post as private info displayed publicly***
Re: 4G speed issue
Can you pop me this info in a PM? I can come back to you publicly once I have received this.
