1745 issues :/
1745 isn't working for me all of a sudden. When I ring it, the voice says 'The number you have dialled is not recognised'. I'm using the same phone that has worked with 1745 several times in the past. Anyone else?
Re: 1745 issues :/
@O_o Thanks for getting in touch with us here to highlight this.  We're working to get this back up running. I'm sorry for any inconvenience caused. In the meantime, you can check your balance in your My3 App instead.
Re: 1745 issues :/
Re: 1745 issues :/
Hi, it's back now, thanks. I do like to use it, it's convenient Smiley Wink
Re: 1745 issues :/
Maestro
Great to hear! Have a lovely weekend!
