Re: SMTP Settings, looking for resolve to issue ASAP.
If you get a working response from Three on this please let me know.
None of the 'solutions' I was given worked so gave up.
Re: SMTP Settings
Re: SMTP Settings
Hi. I am similar to AlanMac's query above in a lot of ways.
I use a Samsung Galaxy A3 and receive incoming emails on my eircom.net account. However I am unable to send emails.
I have tried to change APN settings as in an earlier but I am unable to do so, they are greyed out.
How can I rectify this as I need to be able to send emails
Re: SMTP Settings
I have tried to change APN settings as in an earlier post but I am unable to do so, they are greyed out.
Re: SMTP Settings
Hi MickC 👋 What APN settings are coming up greyed out? You can send me a screenshot of this if you like. Is there an option to reset your settings to default under the APN settings? Did you by this phone from Three?
Hi All,  just an update on this topic as it gets quite a lot of views. The three.ie SMTP relay system will no longer be available on May 31st 2019.
  • You'll find information on what to do Here  (if the outgoing email server provided doesn’t work, you’ll need to contact your email provider for help)
  • FAQs can be found Here
