Huawei Y3
Coming soon to Three, we give you the Huawei Y3.
The latest technology in your smartphone. It has a high-speed processor quad core, which makes your smartphone smarter and faster, so you can get more out of life.
Capture every moment. Perfectly.
You can be sure to capture the perfect image, even in a dark environment. Dual flash enhances the effects and capture capabilities, so you will be able to capture the perfect moments.
Brains equal beauty
5MP camera with dual LED flash plus. 2MP front camera with beauty function to take perfect selfies.
Easy to use.
UI design is simple and easy to use fonts and icons.
Elegant Design.
With a 3D patterned texture, the surface sports a premium surface and is designed with an organic shape that is simple yet elegant.
The Tech Specs
Click here for more
Huawei Y3
OS
Android – KitKat
Display Size
4.0"
Display Resolution
800 x 480 pixels
Camera
5 MP
Internal Memory
4GB
Expandable Memory
Yes (up to  32Gb)
Dimensions
122.6mm x 63.8mm x 10.9mm
Weight
123g
Processor
Quad-core 1.3 GHz Cortex-A7
Network Speed
3G
Standby (Up to)
N/A
NFC
No
Wi-Fi
Yes
Sim
Micro
Keyboard
No
What's in the box?
Click here for more
Device
Battery
1 USB Cable
1 Charger
1 Quick start guide
This phone would be perfect for you if you're thinking of upgrading from the Huawei Y330. Drop any of the Mods a PM if you'd like to chat about your upgrade options Smiley Happy
Re: Huawei Y3
huawei y3 is a very stylish phone.I personally use this phone.It has very battery timing and camera results
