Huawei B525 WiFi doesn't have internet connection
Hi. I have A Huawei B525.
Since this morning started to act very weird.
It has a WiFi signal, but when in connected to it, after a few minutes, it says that it doesn't have a internet connection. I restarted it and after a few minutes of being able to browse on the web, it says the same. I even got to the point of removing the SIM card and putting back again, I restarted and rebooted it, I even reset it to factory settings.. it keeps doing the same thing. Even when I'm connected through Ethernet it doesn't have a internet connection. I checked the router configuration page, it looks like everything is fine from there, the router is actually receiving a good 4G signal, the problem seems to be when it has to give it through the WiFi. Any help please?
Re: Huawei B525 WiFi doesn't have internet connection
@Izma Is this still happening for you? Just to confirm it's happening both Wired and Wireless?
Yes it's still happening.
Thanks for letting me know. You mentioned the issue is through WiFi but if it's happening with the Ethernet cable then it isn't just WiFi so lets go through a few more things here to find out what's happening. From my side I'd like to check your location, can you send me your home address (just the town and county as this is public) Have you tried connecting a few things to the WiFi to use it or is it happening on the same piece of equipment i.e the same computer or the same phone?
Thanx for replying. My address is Knockanure, Ballymakeera, Cork.
I tried the Ethernet and is the same. I tried to connect my phone, my tablet, my wife's phone, my wife's tablet, my smart tv (with WiFi and Ethernet), and a few other devices from my relatives. All of them can pick up the WiFi signal, but when trying to browse on the internet, it won't connect, and it says there is not internet connection although they have a WiFi signal and the modem is showing that it's picking up 4G..
Okay thanks for the information. I've checked my side and there aren't any known issues in the area. Did you see any pop up on the screen at any point about a credit limit just before this started to happen? Can you send me the broadband number, name and date of birth,  I'l check your account right away and come back to you here?
I know.. I have another number with Three, but it works fine. And I just topped my modem 3 days ago..
It looks like the SIM you're using in your modem is a mobile phone SIM card on the All You Can Eat Data Plan. On these type of sim cards there is a fair usage policy of 60 GB which can come into play if other customers are affected by your usage as tethering is not supported. This is likely why you can see the signal and you can pick it up but are having difficulty using it.
I didn't know that. But I just logged in into the modem and changed the settings from auto to 3g only and chose the network manually and now is working. I watched a complete film on Netflix to test it and seems to be working.. I'll try to change it to 4G only and see what happens
Perfect! That's great to hear. I also recommend after you select the network to always put the search mode back to auto and the preferred mode to 3g only as this is the best setting for your area. Shane
