My3
Highlighted
porting issues, no incoming calls
Just moved to three on the unlimited plan
moved from Plusnet, ported number over and realised I can make out going calls
showing my correct number when calling out.
Anyone who tries to call in gets a dead tone
calls from three and the support guys are able to call in.
Spoke with support who then escalated to number porting, got a message a week later to say resolved
worked for one day and now the same issue
The handset is a Samsung S9, when I go into about phone it shows the original sim number and you are unable to change it, even though the support advised I can?
Anyone had same issue or any suggestions?
Thanks guys.
Highlighted
Re: porting issues, no incoming calls
Don't worry about that, when you ring a number 087123456 it actually gets transferred to your IMSI which is your identity.
So the 087123456 can change to 083 etc but your IMSI underneath always stays the same
Highlighted
Think you can edit it in the phone settings but not too sure. I'll look around see what I find
Highlighted
thanks
I have added my number in there, but there is know way to make it the main number, it just sits behind the original sim number.
thanks again.
Highlighted
@storey71 weird and are the other issues sorted then?
Highlighted
it worked for at least a day when support said they had rectified the porting issue threough T Mobile.
Then got home last night and the wife had been trying to call and the line is dead again
they have re-escalated this but fed up now
Highlighted
AH, This is the forum for Three Ireland, you mentioned T-Mobile, that network isnt in Ireland, unless you mean Tesco Mobile?
Highlighted
Hi @storey71 👋 As @billbond4 said, this is a Three Ireland forum so I don't have any access to your account here to help further. I hope you get sorted!
Three – Covid-19
