where do I find info on 3 masts
I live in Woking, which dosnt seem to be very well served by 3 masts - Ive looked at some the online map sites and I just dont see any 3 masts on them. How do I find where they are?
Re: where do I find info on 3 masts
This is a forum for three ireland.
Try installing an app called opensignal on your phone it will show you where what mast your connected to
its 3 ireland? really...well whoopsie
No problem
