using mifi 4G broadband sim in a dongle
hi, I have a 20 gig mobile BB sim that was being used in a Huawei E5573bs-322 device. My requirements have changed and I now need to use this in a dongle so I can connect to my wifi router as a failover internet connection.
I have just purchased an unlocked Huawei E3372s-153-cr, serial port version, as I know that is compatible with the router. Question is, am I ok just to drop my sim into this device and it connect to 3 ok?
Re: using mifi 4G broadband sim in a dongle
Should connect but to be honest I've never tried that. Give it a go and see what happens. If it doesn't work I don't think much can be done from support side.
Posted From Huawei ANE-LX1
it works ok
