Public IP address
I run CCTV cameras from behind a 3 broadband router. Would it be possible for you to assign a public IP address to my sim so I can properly manage the cameras? A dynamic address is fine, i don't need static.
Can this be done for 4G or is it only available on 3G?
I appreciate any assistance you can provide.
Thanks!
Eamon
Re: Public IP address
Think it's just 3 G but not 100% yeah they can do dynamic public. I think you need to give them the number, to make the change and you'll need to change APN as well. Search for Three_Lisa and send her a PM with number.
Posted From Huawei ANE-LX1
will do! thanks for the help.
Hi @tonic11 just checking in with you to see if you're okay? We haven't received any PM yet but you can click on "send me a PM" in my signature if you're still looking for the public IP address. Thanks!
