Unlimited broadband
Pathfinder
Hi folks,
Just wondering how the unlimited broadband works?
does it come with a router?  does it work with xbox?
because i heard its a billpay phone that you get and im worried that if i get it ill have the same issues i am having now with the xbox one ( im using mobile data and it wont work for gaming)
i dont want to pay for the broadband and its still just a phone with the xbox NAT type still strict.
thanks.
Re: Unlimited broadband
Hi @GaryLennon91 You certainly don't get a phone with a Broadband plan 😊 Take a look at our Unlimited Broadband plan here https://bit.ly/2nLK7zc Let me know if you need anything else!
