Static IP
Hi - I have a B525s-323 router on a 750 GB broadband package.
>I was wondering how often a new dynamic public IP is assigned.  Is it only when router is turned off ?  I just check since yesterday and it had already changed over night.
> Also it possible to get a static IP ?
> Otherwise - what is your advice ?
Thanks alot ?
Re: Static IP
@noelsean As far as I'm aware it happens if you switch off your modem off but can also randomly happen as well, I believe. With mobile broadband the only IP we have is dynamic, I'm afraid.
