Problem with broadband speed - Carlow
Hi all.
I am having horrendous issues with my broadband speeds in Carlow.
I am getting very low speeds (around 4mb/s) but the upload speeds are up to 20 mb/s
In addition I have been experiencing loads of connection problems.
This this what I've tried:
1. Got a new sim card
2. Got a new huawei Huawei B525 router
3. Currently using a mobile hot-spot (zte) that works better than the Huawei B525
4. Moved both routers around the house to get a better signal
Nothing has improved the situation.
Three customer support have been less than helpful and now I am stuck in contract for another 10 months.
Can anyone help?
Re: Problem with broadband speed - Carlow
Oh, I forgot to say that the speeds drops down even more in the evening/night after 6pm is usually when it gets really bad.
I also have a three mobile and when I connect my devices to this has a hot-spot the speeds are always, at least, double of what I am getting with the broadband.
More often than not when I experience issues with the broadband the phone Internet is perfect
That new router has two settings in it. I find when I disable the 5ghz frequesncy my speeds are better or if I enable 3G only. Play around with settings because you can always reset the router back to the default settings. It's how I found some changes helped.
At Three we are updating our systems to make your 3Community experience even better. From Friday the 24th of January, the forum.three.ie community will become read-only in preparation for launching a new and improved 3Community later this year. All our useful tips and information can still be viewed in the posts and blogs. Once the new 3Community is ready to go, you will be the first to know. If you are a current member and need help during this time, you can still drop us a private message or alternatively contact us on Facebook or Twitter. Thank you for all your contributions to 3Community and we are excited to welcome you to your new 3Community soon
