Mast issues - Poor Signal/Data in Manchester
Hello,
Since Three have kicked off the 5G upgrades my connections barely usable.
The issues in my area have been going on at least since end of July.
I was informed by Three support that by 15th Sept the issue would go away.
It is now the 23rd and every day i check the Network status the day of update increments by a day.
When will the problem be fixed?  I cannot continue to lose signal and miss calls.
Mobile data is poor, i can at most get 5meg throughput for D/L if i'm lucky but most of the time it's 0.3 on 4G and even worse on 3G when that was offered as a suggestion by support.
I believe i've given Three enough time to resolve their issues and i've been patient throughout the process but there doesn't seem to be a clear path to resolution.
Does anyone have any ideas?
Re: Mast issues - Poor Signal/Data in Manchester
This forum is for Three Ireland users, you would need to contact Three UK for UK issues
3
Understood.
Whats the link to the UK forums, I cannot seem to find it easily.
Unless it doesn't exist..?
I've already contacted support and every day the 'day to fix the issue' increments - same goes for the network status checker.
Doesn't exist. They don't have a community or forun
