Huawei B525 disconnecting
Hi all
I have a problem with my modem, sometimes I have to log in to network every 15 min.
Sometimes it says it is DNS problems. It is better after 22:00 but during the day it goes off way too often. I restart it but helps only for a while. Here is picture of log errors HELP
Re: Huawei B525 disconnecting
I would change the wifi password,so that would knock off all the connected devices. Then connect one at a time. Are you living in a built up area? I find if devices are connecting to the 2.4Ghz there can be interference from other routers/electronic devices nearby
1
@Rob73 are you trying to connect the same device? try disconnecting everything and then using a different device to rule that out.
ipconfig /flushdns and press  Enter. that removes all saved DNS
Try Ethernet cable instead of WiFi and see if it works.
1
Hi Mac
I use 2 laptops and one phone, but it keeps disconnecting each of them. Flushing dns helps only for a while, using cable doesn't make a difference .
1
Thx bill
I try that
2
@Rob73  Hi there, I'm just wondering if you tried the steps that @billbond4 mentioned. Let us know if they worked for you.
