EU Roaming question
Hi there,
I have a Three billpay broadband plan and wanted to confirm how much data is included in EU roaming on this? It looks to be 3GB and then I would be charged out of bundle rates when going over 3GB?
Re: EU Roaming question
So just to clarify this if anyone else comes across this query;  the "Roaming with Three" webpage  identified my plan as "Broadband Plan 1", however with help from @Three_Deborah1 I found out that my actual plan is called "3 Unlimited Broadband-SIMO ROI" and does not include any EU roaming data allowance.
What's the name of your plan? I thought you couldn't Roma with broadband. Are you prepaid?
Hi Michael
It's a billpay plan, I think it's called "Broadband 1 plan"
@terland Don't think that exists anymore since the EU roaming thing last year and I'm nearly sure there is no roaming on Broadband. Just looked on three.ie and all the plans there outline "ROI use Only" If it does work you could end up with woeful fees
@Michael_Mick
Yeah, not sure, I got the 3GB number by going to the roaming page on the Three website, and this is what the result was:
@terland Oh that's great (older plan still has roaming) you're good to use it then but @Three_Deborah1 should be able to confirm just so you know for sure!
Hi all, that sounds like one of our legacy plans, which does have the option of 3GB of EU data. @terland can you send me the number of your broadband1 account, please? So that I can confirm that the booster is on the account.
Thanks for all the help guys, @Three_Deborah1 I'll send you a PM with the number there shortly.
