Broadband unusable in Rathkennt, Navan, Meath
I have posted here before about mobile broadband being slow in my area however it is just getting ridiculous at this stage. We are barely getting 1Mb most of the time which is just not acceptable. The worst part is we actually use to get good speeds of 25-30Mb but in the past 2 years, the service has just been getting worse until now. I do not expect to get speeds equivalent to fibre broadband but I would like to be able to load a website when I need to. Is there really nothing that can be done?
Re: Broadband unusable in Rathkennt, Navan, Meath
@maryfarrelly I'll be happy to help you here. Are you at home with your router now?  If so, we can go through some steps together to see if it helps. If not, you can come back to me here when you are. You're using the B525 Router which is a 4G router but have you tried connecting to 3G only to see if it helps? I've checked your address and there are patches of 4G availability but 3G is more widespread there. Let me know Smiley Happy
Hi Rachel, yes I am home with the router. I have tried switching to 3g however the speeds are still less then 1mb most of the time. I have also tried turning of the 2.4ghz band which I read on another thread however it did not help
Sorry for any delay here, Mary. Turning that 2.4ghz off should help but only if you are connecting your broadband to your laptop via ethernet cable i.e. wired not wireless. Have you ever logged into your modem to view the set up?
Oh I see, I have logged in yes, do you mean any settings in particular?
Your network settings in particular can you Manually select the 3G option in your network settings please?  Make sure you save your changes as well or it will revert to 4G.
I have switched to 3g and I'm getting about 0.6Mbps
Thanks, Mary. If you're using a laptop or computer can you connect the modem to it via Ethernet cable and then run a speed test? Let me know if your speeds change then and we can take it from there.
On ethernet, I got an average of 690 over three tests
Are we talking Kbps, Mary so 690 Kbps? Have you ever tried using the router at a different location and when you got this router did you also get a new SIM with it? Sorry for all the questions. Before i do a full analysis of your service I just want to be able to rule out a few things, if that's okay?
