Highlighted
Broadband is picking up roaming
My modem is picking up a roaming signal even though I am not roaming. It tells me that I will be charged roaming charges when I go to connect. Why is this?
Highlighted
Re: Broadband is picking up roaming
Thanks for the reply Elaine 😊 I hope you saw billbond4 post too! We can all assure you that this is fine and you won't be charged unless you are outside of the country. This is also a normal reaction on older modems in an upgrade area. If you want you can PM me and I'll check your account out.
1
Highlighted
Are you roaming on o2-irl?
There is probably upgrade work ongoing in your area and your roaming onto the O2 network, which is owned by 3, so your fine
1
Highlighted
Hi Elainetgrehan
This notification can indeed appear if your phone connects to a different mast. Your phone is likely detecting this and warning you as a result but so long as you're not actually out of the country, you'll be fine. If you're living near the NI border, this may also be a factor but as EU roaming is included in your plan, it's unlikely you'll have any issues here.
Normally, when you are roaming, even in NI, you'll receive a text from us to advise of rates when outside the Republic of Ireland. If you receive this text, let me know.
Thanks,
Lisa
Highlighted
Hi Lisa
It's not my phone, it's my modem that is showing as roaming. I am not out of the country and not near the NI border.
Highlighted
1
Three – Covid-19
In the interest of ensuring the health & safety of our employees, our contact support centres are open, however we currently have limited resources. This may cause higher than normal wait times.
Under the advice of the government, our stores remain open. We have enhanced cleaning in place and are strongly enforcing social distancing which we encourage our customers to respect. We have also reduced the opening hours in all our stores
Self-serve options such as three.ie, My3 App & Web, 1913 & SMS Codes are also available to you.
For more tips & information, please click here.
We apologise for any inconvenience caused and thank you for your understanding.
