roaming problem
Iv just arrived in Spain today.my phone is receiving calls..i think.but i can't make a call,its connected to orange network.
when I try make a call it says calls to the number I'm tryin to call is restricted.and iv no internet data i have 4G turned but nothing is coming up
Re: roaming problem
Hi christyep91
I'm sorry to hear that! Can you try manually searching for a list of available networks there? Another network may be able to give you a better service, people often opt for Movistar.
Let me know how this goes for you 😊
Lisa
Re: roaming problem
That's fixed it Lisa thanks,could I pm you my number so could you check to see what my data and call allowance is?
Re: roaming problem
Absolutely christyep91, send me a PM with your number, name, address and DOB and I'll be happy to check these for you 😄
Re: roaming problem
Thanks for this Christoper 😊 So while in Spain, your unlimited calls and texts will work as they do at home. You get a data allowance of 9GB, you can keep an eye on it using our MY3 app. You can find out more on that here 👉 3.ie/l8ln9 👍
Re: roaming problem
That's great thanks.👍
Re: roaming problem
No bother, happy to help! If you need anything else, just let me know!
