Upgrade issues
I’ve been with o2/three for over 15 years I feel I’m finding it strange that they can’t match the deal for eir for the same phone and similar price plans it’s 120 euros more expensive makes no sense I’m happy with three but in impressed one bit .any advice or help or should I just join eir
Re: Upgrade issues
Eir - oh I wouldn't! Tempting though with that much of a difference. If I were you I'd PM @Three_Mairead or @Three_Deborah1 and see if they can give you a better deal. If not then make sure you do your research before you jump ship.
Re: Upgrade issues
Thanks very much for the quick reply 👍
