Re: Three Broadband Huawei E3531 dongle not instal
Hi @Anonymous, that download should have fixed it for you, can you get in touch with Huawei here to check that there isn't another driver you're missing for it to work with Mac? - http://consumer.huawei.com/en/support/index.htm
Let me know how you get on.
Hi @Anonymous
You might want to un-install what you have installed and then do a reboot and re-install it, bit of a work around I do admit, but does the trick!
Thanks everyone, I'll try to see if it works and will get back to you if there's any problems.
Great, let us know how you get on Smiley Happy
Hi there,
Thanks for posting on the Three forum.
I am just wondering if your query had been solved. If so, would you mind clicking the “Accept as Solution” button on the right bottom of the answer that had solved your query?
By marking the reply that solved your issue it is likely that another member will be in need of the answer and we can point them in the direction of the solved answer from this thread.
Thanks again for using the forum.
