Signal booster
I live in area that has zero mobile phone coverage for any network. A few meters outside my house I get a 3 signal but not in the house. We have a 3 router attached to the side of the house which we get sufficient internet from. My question is there any booster I can purchase to help boost my mobile phone signal in the house. I simply want to be able to make and take calls. Thanks
Posted From Apple iPhone
Re: Signal booster
Unfortunately signal boosters are illegal in Ireland, your best bet for calls is to use a WiFi call in your house via an app and setup call forwarding on your phone when your not reachable to the phone number the app gives you
Re: Signal booster
Maestro
There are lots of boosters but not with Three. Read up on the reviews for boosters and order online so you can send it back if it doesn't work.
Re: Signal booster
Re: Signal booster
Thanks very much for the speedy reply!
Re: Signal booster
Maestro
@billbond4 illegal! I had no idea! Whoops
