Port Forwarding
I've setup a virtual server on the huawei b525 router for port forwarding but it is still not working.
Is there anything else that needs to be set up or are there any ports that are blocked?
Re: Port Forwarding
FYI
I was using whatsmyip.org to get my public IP. Is there a better way to check this or can someone check what my public ip is?
And is it possible to get a static public ip address?
Re: Port Forwarding
Hi @ashannon Can you PM your broadband details and I'll certainly look into this further for you?
