Re: My roaming didn't work in Finland
Can you also have a look at this link here and let me know if this helps 👉 http://bit.ly/2wLOCNa
Do you have iphone?
Posted From Sony G8441
I’m having the same issue. Data roaming not working at all and when I tried to get it resolved on chat they didn’t know how to fix it.
Posted From Apple iPhone
Iphone?
Yep, SE!
Yip thats the problem, what apn are you using?
can you change the apn to 3Internet
Hi @Anna 👋 Did you get data connection? Did you try the suggestion of changing your APN? Let me know and I can look into this further for you? Mairéad 👍
Hi Mairead, tried changing the APN as suggested but it didn't work. Myself
and my boyfriend had the exact same issue the entire time we there -
neither of us could get data at any point with any of the Finnish networks.
Couldn't get the issue resolved by phone or by chat with 3, despite both of
us trying everything that was suggested. There seems to be a much wider
issue at hand with data roaming in Finland.
Does he have an iPhone also?
