Highlighted
Re: My roaming didn't work in Finland
Hi, I'm using 3ireland.ie.
thanks!
Highlighted
Hmmm... I might be incorrect, I attempted to call to 1913 but just someone automatically spoke in foreign language not English. It might mean I don't have any international contacts?
I could use three sim in Norway, Estonia, Germany, so I was assuming I could use it here as well...
Highlighted
What network are you currently connecting to? Can you try connecting to DNA, Elisa or Alands Mobiltelefon Ab?
Highlighted
Try using 3internet as your apn for a minute and make sure your not charged.
If that work's then your sorted
Highlighted
1913 is a short code internal to each country so in Finland it will conect you to a Finnish number.
You need to dial +353 83 333 3333 for 3 Ireland support
Highlighted
I tried to connect to DNA, Elisa and sonera. Only DNA is connected but internet isn't working.
Highlighted
Try this Mayu and let us know how you get on.
Highlighted
I ended up getting Finnish sim card as the 3 customer support was no help back in late August.
Highlighted
The apn is the issue, if you can change it you will be sorted.
Highlighted
I tried this way but it's still no signal of 3G of 4G...
Three – Covid-19
