Minimum prepay top up on 3
My 2 tweenage kids have mobiles on Lycamobile as they allow a minimum top-up of a fiver and the call charges are quite good.
I frequently have problems sending texts so I would like to switch them both to 3 and retain their existing numbers as my wife and I both have post-pay accounts on 3 .
Does 3 also allow a minimum top-up of a fiver and is there a recommended package for kids ?
I only want them to be be able to make calls and text, no data allowance needed.
Re: Minimum prepay top up on 3
Okay so keeping the number, that's easy but the only plan available on prepay with Three is €20 top up for data and texts. If you top up by €5 then you activate nothing and get charged like 17c for a text and 38c for a call. It's hardly worth it. Might be better with another network
