Highlighted
Re: I need a signal booster
3 Staff
Were you able to check the above checklist anyway to make sure you're settings are as they should be?
Highlighted
Pathfinder
I did Fiona
It didn't get better.
I will repeat again tomorrow in case I put in something wrong
Regard
Highlighted
Pathfinder
Thank you Guys
Today I bought Broadband 5 bundle from three with Huawei B315, I am getting a speed of 1.5 to 4mb in my conservatory. which is good. this router must be very good to get that. and hopefully the signal will get better later this year.
Just a Question:  when reading the manual I noticed that you can buy antennas for the router. any idea where can I get them
Regards
Naser
1
Highlighted
Good to hear that you are getting service. You may be able to get one from the likes of eBay etc I'm not sure what exact connection the antenna ports are on the router you have.
Highlighted
Highlighted
http://www.ebay.ie/ulk/itm/281830110182
Cheaper ones but they might not be as good as the one in the post before this they are two smaller aerials that are not an external antenna.
Highlighted
You might not need the aerials, try to get that router up high to try and see can you get an even better reception.
1
Highlighted
True the location of these routers can be everything even a slight movement or elevation can help so much Smiley Happy
Highlighted
Pathfinder
Thank you J
Highlighted
Pathfinder
Thank you B
1
Three – Covid-19
