EU data add-on required
I am currently in Spain and I need some additional data for this month. Can I get about 5GB or more as an add-on? What will that cost?
Ian
Re: EU data add-on required
Maestro
Hi Ian,
We can add on additional data for you. I can add another 5GB for an additional €17.
Maestro
Hi Ian,
Accepted - I will send you my details via PM
Hi - still waiting on confirmation of this -  I already sent my details via PM
Hi - you can remove this from my account now. I do not want it to renew. Ian
Hey @eyeohbee 👋 I have this removed now for you 👍 Mairéad
Hi - I am in Ireland, can I get data added to this line ? WHat are the data add-on options ?
Maestro
Hi there,
Yes you sure can. If you log into your My3 account you'll have the option to buy a  data add on http://bit.ly/1nzWoof 👍
I'm on bill pay and I don't see that option.I always have to ask someone to put add the data (I think). what options do I have?
Maestro
How much data are you looking for? Would you be heavy user? You can get 100MB all the way up to 10GB. I'd suggest getting enough to suit your usage http://bit.ly/2BrJu7s
