Data roaming in Italy. ... again
Have looked at other posts and can't work out why I have no data in Italy. Can make phone calls OK but not use internet or messenger which is very inconvenient ... especially as I have not been able to connect to all of the local wifi networks either.
Re: Data roaming in Italy. ... again
@Carrie That sounds like a phone problem. Wifi is wifi and data is completely separate. Are you on your own or can you test your sim in another phone? Manaully searched and connected to each available network? What have you don't so far to get data connection? Oh are you prepay or bill pay.
Are you on iPhone? Reset your network settings
