Highlighted
Broadband Speed
Hi there, bought a pay as you go sim for my phone....broadband speed is awefull,  0.16mbs down and 0.04 up.
I've tried the sim in different devices with no ipmrovement.  Full, strong signal.
Highlighted
Re: Broadband Speed
Hi @Anonymous, is this a voice Prepay SIM that you're using in a phone, or a broadband Prepay SIM?
What phone are you using it in, and do you know if others on Three have the same issues there?
Highlighted
Re: Broadband Speed
Hiya It's a voice prepay.  Devices tried:
Samsung Galaxy s2
HTC Rhyme
Lenovo smart tab
Hauwai smart phone
....don't know about others problems.  Coverage map shows I should have 4g coverage.  (No devices are 4g)
Highlighted
Re: Broadband Speed
As you're using Android phones, can you check that your settings match these? - http://bit.ly/1FaLhaC. Also can you make sure that your Network Mode and Network Selection are set to Auto, and then restart the phone?
Highlighted
Re: Broadband Speed
Yes...done that.  The trouble is it starts off ok (ish) then gets slower and slower...the stops within 2 or 3 minutes
Highlighted
Re: Broadband Speed
Would it be possible to pop into a Three store and pick up a free replacement SIM card? It's possible that the SIM you received is faulty.
Three – Covid-19
