on 31-07-2017 10:07 AM
just wondering are calls to voicemail included in my plan? I'm on an unlimited flex max sim only plan (€30pm).
Looking at my bill (see screenshot of relevant section) they appear to be, but if I'm interpreting Three's info correctly on this they shouldn't be. Can you clarify this? Thanks.
on 31-07-2017 11:05 AM
Hi there 👋 Premium rate call's wouldn't be covered by your plans units, these would be calls to 1800 numbers for example. Your plan would cover you for voicemail, here's a link to out of bundle rates http://bit.ly/2oeT86I
31-07-2017 11:40 AM - edited 31-07-2017 11:41 AM
Thanks for that Stephen. I had read that document previously too. I've attached a screenshot from it.
The bit I've pointed to says: 'Voicemail is always charged out of bundle', hence my original query re Flex Max plans and calls to Voicemail.
on 31-07-2017 12:34 PM
I've checked this out and when you call 083 3333 171 you won't be charged, but you should be charged for dialling 171. Have you a voicemail add on included? Could you send me on your number, address and date of birth in a PM so I can have a look at your account?
on 31-07-2017 01:12 PM
Stephen, PM sent.
on 02-08-2017 11:11 AM
Hi, any updates? Thank you.
on 02-08-2017 11:42 AM
Hi there 👋 I've got back to your PM 👍
on 29-08-2017 01:37 PM
Just wondering was this issue looked at further?
on 29-08-2017 01:55 PM
Hi there 👋 You should be charged for calls to voicemail. Can you confirm your address and date of birth in a PM and I'll have a look at your latest bill.
on 29-08-2017 02:03 PM
PM sent.
