Highlighted
4G data speed from mast at Kiltimagh, Co Mayo
Hi, 4G data download speeds from the above mast have been only 0.5Mb at times in recent weeks, which is unusable. It's the same across both prepay and bill pay (business account) using the three network. Uploads are generally fine.
Is there work ongoing to correct this?
Highlighted
Re: 4G data speed from mast at Kiltimagh, Co Mayo
Hi, there is work being carried out on a mast nearby, this would impact your service. Our tech team hope to have the work completed as soon as possible 👍
Three – Covid-19
