Xperia L2 announced with 5.5-inch HD display and wide-angle
Sony Mobile has unveiled its latest entry-level smartphone, the Xperia L2 (H4311, H4331). The model follows up on last year’s Xperia L1, and continues to use a 5.5-inch HD (720p) display and the same MediaTek MT6737T chipset, but there are a number of improvements.
The Sony Xperia L2 uses 32GB internal storage (24GB usable) and 3GB RAM – versus 16GB storage and 2GB in the Xperia L1. The battery has also seen a significant improvement, moving from 2620mAh in the Xperia L1 to 3300mAh in the Xperia L2.
Rear camera duties are still taken care of with a 13MP 1/3.06-inch sensor with F2.0 lens, but the selfie camera has been upgraded from 5MP to a 8MP 1/4-inch sensor with 120-degree wide-angle F2.4 lens.
Sony utilises its ‘loop surface’ design, with the Xperia L2 also featuring a rear-mounted fingerprint sensor (now usable in the United States). Other features include Corning Gorilla Glass for durability, Bluetooth 4.2, NFC, microSD memory card slot and USB Type-C.
The Sony Xperia L2 has dimensions of 150 x 78 x 9.8 mm and weighs 178 grams. It will launch in three colours (Black, Gold, Pink) with Android 7.1.1 Nougat, when it starts shipping later in January 2018.
If you haven't already registered, now is a good time to do so.
