Re: RE: Android 8.0 / Oreo for Samsung S8
@NC As its a non Three phone you are using, we have no way to make the software available for it as we are only able to do this on phones bought from the network directly. The update will be available to you but unfortunately, I don't know when this will happen. There might be other users here in a similar situation that may be able to shed some light?
Thank you so much for your effort as well for the valuable information. Will keep on checking fir the update.
Ok, I will check my phone when I will free and also thanks to you to tell us...
Top Discussions
