Fix for No more notification lights after Pie update
If you not seeing your custom notifications / LED  notifications  after the Android Pie update.
Go to settings and search for Custom Restrictions and you can toggle the blink option.
Re: Fix for No more notification lights after Pie update
Mine hasn't updated yet but will def do this if that happens
