Issues with 3plus
Hi guys. I'm having issues with logging into 3plus app. Previously registered and won't let me login (I know my password). I know there's been issues before. I can't 're register either. Any other ways to get pre sale codes or how do I sort this out. Thanks in advance
Re: Issues with 3plus
Thanks Rachel but I've managed to 're register with a different email address.
Posted From Samsung SM-G950F
I think there is issues with it at the moment ,as i can just login but I dont see any of the offers etc.
its working for me now, just a bit slow
Mine won't work at all. My partners will but mine won't.
perhaps clear the apps cache and data and then login in again
@michaelwhelan87 PM your number and I'll check it out for you.
No problem, you know where we are if you need a hand 😊
