  • Three_Deborah1
  • 10-05-2019
  • 428
  • 4
How to get a Public IP for Broadband
by 3 Moderator on ‎10-05-2019 04:26 PM - last edited on ‎06-09-2019 12:25 PM by 3 Community Manager (428 Views)
One of our most popular questions on the Forum is about IP addresses. I’ve put together this article to help explain what it is we can do with mobile broadband accounts. Please note this is not something we can change in the background for anyone using a phone SIM.
A public IP address is required to operate video surveillance (CCTV for home, businesses and calving sheds) and other security systems such as gates.
We can change the APN settings on any of our broadband plans (Bill Pay and Prepay plans) to allow a Public IP address.  Because our broadband signal is over the air, your Public IP will be dynamic. This means it can change so it it’s not static. If the connection ends for any reason then an new IP will be used but that remains public.
What to do next?
You'll need to get the mods to change settings on your account. Follow the steps below before you PM
  1. Check your broadband number
  2. You must be the account holder
  3. Join the community and get involved.
  4. Pop on to one of our Public Posts and say Hello (only if it's your first time)
  5. PM one of the MODS with your number, name, address, and date of birth👉 #MeetTheMods
Don't forget to like this post if you found it helpful 👍
Comments
by
on ‎31-07-2019 03:42 PM
This article doesn't actually tell me what to do
by
‎06-09-2019 12:22 PM - edited ‎06-09-2019 12:23 PM
@Patrickstrad  It does it says:
  1. Join the community and get involved.
  2. Pop on to one of our Public Posts and say Hello
  3. PM one of the MODS 👉 #MeetTheMods
Basically only the mods can put the public IP in place but to contact them you have to post at least once in the community and then PM the mods. Communities are all about being out in the open so other visitors can learn what they need to do as well if they have the same issue or question or whatever which is why the one public post is required.
Pretty sure any care channel can help but in my experience the mods here are a lot quicker and know more than the normal customer care person.
