Data roaming not working abroad (Greece)
My iPhone 6 data roaming is switched on but for some reason it is not working abroad.
My girlfriend who has a spanish SIM have no problem with her data roaming, she has 3g with Cosmote, so I'm not sure what the problem is.
Re: Data roaming not working abroad (Greece)
Hi there 👋 Can you switch your 4G off, and manually select a network? If you could send me on your full name, number, address and date of birth in a private message and I'll follow this up?
Hi, I tried switching off 4G with no success. I could connect using WIND with 3G in Athens but now I'm in Kastraki and with COSMOTE my girlfriend still gets 3G but I just can connect manually using WIND with gprs connection and doesn't work well even with WhatsApp.
Is there any way to connect to COSMOTE using a THREE simcard? it seems to be the network more reliable here in Greece.
What options pop up when you manually select a network? Can you try them and let me know how you get on?
Hello,
I have the same problem in Greece. My samsung S6 roaming is switched on but for some reason is not working abroad.
I already tried to:
- Reset network settings
- Remove sim card
- Restart phone
The carrier in Greece is Wind.
Can you please help on this?
Best
Hi @mihchalis, is it data or calls and texts that are affected? What options come up when you manually select a network?
Hello,
Data is affected. How can I choose network?
What type of phone are you using?
Samsung S6
##- Please type your reply above this line -
whats the apn?
If you haven't already registered, now is a good time to do so. Register now >>
