Port Forwarding HUAWEI router
Has anyone managed to get port forwarding working on a 3mobile router? I have tried everything with no luck which leaves me to believe that port forwarding is blocked on the 3 network.
Thanks for any help in advance.
Mark
Re: Port Forwarding HUAWEI router
Solution
Accepted by Three_Sheena (3 Community Manager)
‎06-06-2017 12:56 PM
Hi Marky, I will need you to send me on the Broadband number or the SIM number to do this. The SIM number will start with 893530. Can you pop me these details by PM, please?
Hey Marky 👋 Are you trying to move a number onto a new Three broadband SIM card? Mairéad
Hi, I have my sim in a mobile router. I am able to access the internet and all that but I just want to be able to forward a port so I can access files on my home computer remotely.
Posted From Android 6.0
Could you send me your number, address and date of birth and in a PM and  I'll check this out for you?
could someone post the apn and the settings for a 3 mobile router maybe im having issues because im using the wrong settings.
regards
after some more googling i found the folling thread and it says that 3 must update my 3 account so i can use a public ip address.
could you please do this
Solution
hi
pm sent
New Member
Hi Brogan,
I have just PM you regarding the same problem, could you look into for me please?
Cheers,
Search the Community
Top Liked Authors
Hot Topics
How to turn off the Adult Content Filter
