Need help
I topped up my old phone number at ATM of 20 Euro instead of my recent number how can I receive the credit back
Posted From Android 6.0
Re: Need help
Hi there, is the old phone number still active? Once credit applies to an account it's non transferable or refundable? If you PM the details I can check if the account is still active?
Re: Need help
No the number not active it's *********
My current number is **********
Re: Need help
Can you send those details in a private message and I'll follow this up for you? I've edited your previous message as you posted the details publicly.
